02-14-2011 09:24 AM - edited 03-16-2019 03:26 AM
I am hoping there are some CISCO voip guys out there in Dubai who can help me. I am based in UK and im trying to get a E1 up and running in Dubai.
The provider ETISALAT have provided me a E1 that I have connected to a MGCP gateway.
The problem is I dont know what settings to use, i have tried a few and nothing works. The local guy on site has been trying to contact the provider but so far they have not responded.
Can anyone suggest a setting that may work with this provider?
Colin
02-14-2011 10:15 AM
Just a thought: you may need to route your traffic over a VPN as many of the telcos in the GCC block voip traffic
Good luck getting any sense out of Etisalat. I tried to get them to do a payment gateway once and it took 3 days to find anyone who even knew what that was. We never did get it working...
02-16-2011 04:04 AM
Thanks for your reply.
I thought i would answer my own question since it may help some other people out there. Etisalat used the following settings
Line code HDB3
Framing CRC4
Encap HDLC
Isdn switch-type primary-net5
My e1 is up and running now on my MGCP gateway, i used the standard euro settings to get it working.
All i have to do now if fix a one way transmission issue.
regards
colin
07-01-2011 02:02 AM
Thanks for the information; i'll be out in Dubai next week installing a new cluster.
Do you know whether I need a cable with special pin-outs between the NTU and the Gateway, or can I use a regular straight through ethernet?
Cheers,
Phil
