10-04-2016 06:35 PM - edited 03-17-2019 08:16 AM
Hello all. New to Cisco here and need some guidance.
My system is a. UC520-8U-2BRI-K9. The system has 2 BRI ports built in which i do not plan to use at all, So i purchased a VIC2 FXO card.
Card seems to work fine on incoming calls when setting up incoming rules in CCA. Also things work fine when adding the line to a button on one of the phones.
However i would like to configure the line to not appear on any of the phones, instead having to dial an access code such as 9 to grab the line.
This is the error i get: ERROR:destination pattern cannot be configured when stcapp is configured on a dialpeer
Here is the commands i am using.
Can anyone point me in the right direction? how do i remove STCAP? and configure for US dialing?
UC520#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
UC520(config)#voice-port 0/2/1
UC520(config-voiceport)#connection plar 801
UC520(config-voiceport)#caller-id enable
UC520(config-voiceport)#exit
UC520(config)#dial-peer voice 2 pots
UC520(config-dial-peer)#dial-peer voice 1 pots
UC520(config-dial-peer)#destination-pattern 9[2-9]......
Thanks for your help
Solved! Go to Solution.
10-05-2016 05:32 PM
Hi Keith,
Glad to help! Please rate the helpful posts and accept it as an answer if it helped. Regarding the query for 1800 numbers, you can either create another dial-peer, specify the FXO port under it and set the destination pattern to 91800T or you can create only one dial-peer and set the destination pattern as 9T which will cover the complete US dial-plan.
Aseem
10-04-2016 09:05 PM
Hi keith,
Can you please attach the running configuration?
Aseem
10-05-2016 10:24 AM
10-05-2016 11:38 AM
Hi Keith,
FXO ports are just H323 ports. Stcapp is always configured for FXS and is never configured for FXO ports or FXO ports should never be associated with a stcapp dial-peer.
You can try to remove the dial-peer by running the command "no dial-peer voice 1 pots " and reconfigure it without the stcapp command.
Aseem
10-05-2016 12:44 PM
Thank you so much. i will try that and report back when i can as to the result of that command.
10-05-2016 01:48 PM
That worked! Thank you so much! One more question for you. The only problem i have now however is the dialing. I have the destination pattern set as 9[2-9]......
which does not allow me to dial 1-800-XXX numbers XXX-XXXX. How would i set up that destination pattern to allow me to how the option to dial 1-800-XXX-XXXX or 1-Area code-XXX-XXXX calls?
Toll fraud or blocking numbers isnt an issue, this system is in my home.
10-05-2016 05:32 PM
Hi Keith,
Aseem
10-05-2016 09:44 PM
Once again thank you, Rated accordingly :)
