HI any one aware of any lapel microphone system which could be used with Cisco 8831 conference IP phones?
Shobhiy
Level 4
Level 4
HI any one aware of any lapel microphone system which could be used with Cisco 8831 conference IP phones? I am not sure whether the other vendors Lapel mics could be used with Cisco 8831?
Thanks and Regards
Shobhit
MarcusPresidio
Level 4
Level 4
The 8831 does not support a 3rd party microphone and Cisco does not make a lapel microphone.  Customers usually register buy a third party SIP device that supports a lapel microphone.
http://www.revolabs.com/products/conference-phones/wireless-conference-phones/voip-bluetooth
is this also true for Cisco 7937?
The 7937 has an option
7937 supports lapel MIC kit. I had exchanged emails with the BU and here is what they had to say
Here is what's available and tested from Polycom...
Wireless SoundStation Microphone System, Frequency A = 171.905MHz : SoundStation, SoundStation Premier and SoundStation2 - ** See Footnote Below Regarding Frequency and Country Availability
$399
2200-00699-001
Wireless SoundStation  Microphone System, Frequency F = 203.400MHz ¿ SoundStation, SoundStation Premier and SoundStation2 - ** See Footnote Below Regarding Frequency and Country Availability
$399
2200-00699-002
Product Family Subsection Footnote -
** Available in the U.S. only -- frequencies may interfere with other public networks.
** Two frequencies are available to avoid interference if 2 units are used in adjoining rooms.
Also, here are some comments (below) from Polycom on the use of non-Polycom wireless mics;
Based on email traffic, you’ve had quite a few requests for information about wireless mics.  As I mentioned, we only tested with the Polycom wireless lapel mic (available in NA through standard channels such as Ingram, Tech Data or local resellers to include DMRs like CDW) and the AudioTechnica.  The Audio Technica did not test well and we are not recommending it.
In general, however, I did get some feedback from our audio engineers.  This should help you out.
The VTX1000/SoundStation2 support an external microphone via the AUX IN jack, when the device menu is set up appropriately.  The 7937 supports this same function via its 2.5mm connector.  This external mic can be wired or wireless, the only constraint is that this needs to be a “line level" signal.
  1. a.  Most wireless mics are line level by design.  Hence, most good
    wireless mics will likely work fine.  We've tested our own wireless (for
    domestic market) and the Shure SLX (for international), to be able to
    give a specific confident answer to this question, but the fact is that
    many more will work.
    b.  Most studio and conferencing mics are "mic level", which is a much
    lower level.  They are normally amplified using a preamplifier module or
    a sound mixer (for multiple mics).  Consequently, a microphone plus a
    preamp would work fine with the VTX1000/SoundStation2 or Rockpile.
    Two examples of wired microphones are the Shure SM58 (classic microphone look)
    or the Shure MX418 (very compact).  They can be gooseneck-mounted, or on
    a desktop stand.  But there are hundreds that will work; these are just
    the two we've  experimented with recently.
Thanks good to know
