241
f-vanryckeghem
Beginner
Hide calling name for specific calls (internal)
This  is  what  I  would like to  configure.
All the phones belonging to  a partition ( Internal_guest) may  call each other,  but when calling,  the calling  party name and called party name should not  appear on the phone.
But when calling phones in another partition ( Reception),  the callin/called party name should be present on the phone.
I  have tried several things with transformation pattern but ..no  result
Thanks a lot  for any hint
Frederic
1 REPLY 1
You will need a xlation pattern to achieve this. On the xlatipn pattern you can then set the calling name presentation to restricted and the connected name presentation to restricted.
Please rate all useful posts
Create
Recognize Your Peers
Content for Community-Ad
