08-25-2016 01:50 AM - edited 03-18-2019 12:06 PM
I just implement CMC code to restrict users being making calls without enter the CMC code. But I faced problem that when the users prompted to enter the code or password, the code appears so anybody can see it. Does anybody know how to make that password invisible to others?
Best Regards,
08-25-2016 02:01 AM
CMC is not considered as secure, hence this is working as design.Try using FAC instead.
12-25-2016 03:32 AM
Hey folks,
Am implementing PCCE v11.0.1 solution in INTERNATIONAL BPO. International PRI's is terminated on gateway. Am configuring FAC on CUCM v11.0.1 and somehow FAC code is displayed on IP Communicator. Calls donot route but if FAC is removed calls pass through Gateway successfully. I've worked earlier on v10 versions.
Made sure about following things...
Is there am missing any, please suggest.
As far am aware NO SPECIFIC FAC codes are required for International PRI's.
Thanks & regards,
Ritesh Desai.
12-25-2016 11:02 PM
hey team,
Any luck... I tried replacing to different CIPC v8.6.4.3 ES patch, though bad luck. Earlier I was using CIPC v8.6.1.
regards,
Ritesh Desai.
12-26-2016 06:48 AM
hey folks,
Found the root cause for this. SIP doesnot hide the FAC. SCCP hides the FAC code.
regards,
Ritesh Desai.
