Hide Network configuration option from Cisco IP Phone
Youssef Aoufi
Level 3
Level 3
Hi all,
I want to know if there is a possibility to hide some menu options like network configuration from a 7900 series ip phone.
Thank you in advance
paolo bevilacqua
No, but they can be password protected.
Thank you Paolo for your prompt answer,
I am very interested about the password protection solution.
Could you explain me how can i do it?
I am using CUCM 8.5 .
Thank you very much
Rob Huffman
Hi Youssef,
Just to add a note to the good tips from Paolo (+5"P")
On the Device Config page in CUCM > under Product Specific Config >
Settings access>
change to Restricted
The option Restricted is available in Cisco CallManager version 4.1(3) and later. When you change Settings Access to Restricted, you can only access User Preferences and volume settings. By default, Settings Access is enabled.
Cheers!
Rob
Thank you very much Rob,
The information you gave me was very helpful.
I am also interested on the password encryption method.
Best regards
