Hiding "Phone information" menu on 3905 IP Phone
jonathanspruyt
Hello All,
For a customer in a high security environment we're installing 3905 phones for public usage. The problem is that these phones still display a "phone information" menu option which contains ip addresses for the phone and the active callmanager which is not acceptable for the client.
The phone configuration for the settings menu is already set to restricted, but the "phone information" menu is still available. I've seen the same behaviour on a 6941 IP Phone at another client.
Is there a way to disable this?
Kind regards,
Jonathan
singhaam007
Level 3
Level 3
Hi Jonathan,
You can apply a password to the phone so that no changes can be made to the administrative options on the phone without the password being entered on the Admin Settings phone screen or even user can access those menus.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/3905/8_6/english/admin_guide/3905net.html#wp1097451
hope this will help you.
please rate if you think this is helpful
thanks
Paul Freiberg
