08-11-2011 05:46 AM - edited 03-16-2019 06:25 AM
could you point me what can be cause the following issue on router 2811. The issue is not permanent it can be occured up to 10 times per day. Sometimes is ok. The Router is just voice gateway with 2 E1 card connected to NEC PBX and one fastethernet interface connected to lan :CUCM - H323. IOS version is c2800nm-ipvoicek9-mz.124-24.T3.
When issue occure the router generates the error with multiple call rejected:
%IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=110199) is rejected.
Thank you in advance.
#show call active voice comp
<callID> A/O FAX T<sec> Codec type Peer Address IP R<ip>:<udp>
Total call-legs: 476
138508 ANS T111 g711ulaw VOIP P2424 172.16.152.238:17872
138509 ORG T111 g711ulaw TELE P9XXXXXXX
138566 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138567 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138568 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138569 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138570 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138571 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138572 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138573 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138574 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138575 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138576 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138577 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138578 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138579 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138580 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138581 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138582 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138583 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138584 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138585 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138586 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138587 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138588 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138589 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138590 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138591 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138592 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138593 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138594 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138595 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138596 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138597 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138598 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138599 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138600 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138601 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138602 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138603 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138604 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138605 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138606 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138607 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138608 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138609 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138610 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138611 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138612 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138613 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138614 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138615 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138616 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138617 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138618 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138619 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138620 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138621 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138622 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138623 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138624 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138625 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138626 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138627 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138628 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138629 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138630 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138631 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138632 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138633 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138634 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138635 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138636 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138637 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138638 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138639 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138640 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138641 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138642 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138643 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138644 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138645 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138646 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138647 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138648 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138649 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138650 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138651 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138652 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138653 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138654 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138655 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138656 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138657 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138658 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138659 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138660 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138661 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138662 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138663 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138664 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138665 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138666 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138667 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138668 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138669 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138670 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138671 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138672 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138673 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138675 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138677 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138678 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138679 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138680 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138681 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138682 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138683 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138684 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138685 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138686 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138687 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138688 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138689 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138690 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138691 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138692 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138693 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138694 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138695 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138696 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138697 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138698 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138699 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138700 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138701 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138702 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138703 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138704 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138705 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138706 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138707 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138708 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138709 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138710 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138711 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138712 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138713 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138714 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138715 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138716 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138717 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138718 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138719 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138720 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138721 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138722 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138723 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138724 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138726 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138727 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138729 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138730 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138733 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138734 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138735 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138736 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138737 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138738 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138739 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138740 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138741 ANS T75 g711ulaw TELE P5330
138743 ORG T75 g711ulaw VOIP P2473 172.16.152.243:19568
138746 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138747 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138750 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138751 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138754 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138755 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138758 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138759 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138762 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138763 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138766 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138767 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138770 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138771 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138778 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138779 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138805 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138806 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138807 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138808 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138809 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138810 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138811 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138812 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138813 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138814 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138815 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138816 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138817 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138818 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138819 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138820 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138821 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138822 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138823 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138824 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138826 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138825 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138827 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138828 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138829 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138830 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138831 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138832 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138833 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138834 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138835 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138836 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138837 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138838 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138839 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138840 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138842 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138841 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138843 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138844 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138846 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138845 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138847 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138848 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138850 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138849 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138851 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138852 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138854 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138853 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138855 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138856 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138858 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138857 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138859 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138860 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138862 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138861 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138863 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138864 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138865 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138866 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138867 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138868 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138869 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138870 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138871 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138872 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138873 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138874 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138875 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138876 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138877 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138878 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138879 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138880 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138881 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138882 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138883 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138884 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138885 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138886 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138887 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138888 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138889 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138890 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138891 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138892 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138893 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138894 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138895 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138896 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138897 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138898 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138899 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138900 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138901 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138902 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138903 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138904 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138905 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138906 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138907 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138908 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138909 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138910 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138911 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138912 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138913 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138914 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138915 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138916 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138917 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138919 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138920 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138921 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138922 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138924 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138925 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138926 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138927 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138928 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138929 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138930 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138931 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138932 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138933 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138934 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138935 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138936 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138937 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138938 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138939 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138940 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138941 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138942 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138943 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138944 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138945 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138946 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138947 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138948 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138949 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138950 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138951 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138952 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138954 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138956 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138957 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138958 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138959 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138960 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138961 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138962 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138963 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138964 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138965 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138966 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138967 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138968 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138969 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138970 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138971 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138972 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138973 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138974 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138975 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138976 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138977 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138978 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138979 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138980 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138981 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138982 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138983 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138984 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138985 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138986 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138987 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138988 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138989 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138990 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138991 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138992 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138993 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138994 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138995 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138996 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138997 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
138998 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
138999 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139000 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139001 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139002 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139003 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139004 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139005 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139006 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139007 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139008 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139009 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139010 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139011 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139012 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139013 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139014 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139015 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139016 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139017 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139018 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139019 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139020 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139021 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139022 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139023 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139024 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139025 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139026 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139027 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139028 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139029 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139032 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139033 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139034 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139035 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139036 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139037 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139038 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139039 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139040 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139041 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139042 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139043 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139044 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139045 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139046 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139047 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139048 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139049 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139050 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139051 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139052 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139053 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139054 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139055 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139056 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139057 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139058 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139059 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139060 ANS T0 None TELE P1320
139061 ORG T0 g729r8 pre- VOIP P2432 0.0.0.0:0
139062 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139063 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139064 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139065 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139066 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139067 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139068 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139069 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139070 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139071 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139072 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139073 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139074 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139075 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139076 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139077 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139078 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139079 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139080 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139081 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139082 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139083 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139084 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139085 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139086 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139087 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139088 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139089 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139090 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139091 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139092 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139093 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
139094 ORG T0 g729r8 pre- VOIP P7325 0.0.0.0:0
139095 ANS T0 g729r8 pre- VOIP P6480 0.0.0.0:0
08-11-2011 06:59 AM
p.s. Extension 6480 belongs to PBX and 7325 to IP phone registred on CUCM. That is the call comes from PBX to CUCM and for some reason dublicated multiple times.
card type e1 0 0
card type e1 0 1
network-clock-participate wic 0
network-clock-participate wic 1
isdn switch-type primary-net5
isdn gateway-max-interworking
voice-card 0
controller E1 0/0/0
framing NO-CRC4
clock source internal
pri-group timeslots 1-31
controller E1 0/1/0
framing NO-CRC4
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
no snmp trap link-status
isdn timer T310 120000
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no cdp enable
dial-peer voice 9 pots
service name3 ; Performs phone number to name map for PBX extensions
incoming called-number .T
direct-inward-dial
dial-peer voice 73 voip
preference 2
destination-pattern 73..
voice-class codec 1
voice-class h323 1
session target ipv4:172.16.152.252
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 773 voip
voice-class codec 1
voice-class h323 1
session target ipv4:172.16.152.254
no vad
08-12-2011 03:43 AM
Does anybody know? Any ideas will be very helpful. I dont understand why peer address P6480 marked as VOIP instead TELE. Analog phone with number 6480 belongs to NEC PBX and calls from it directed to router's E1 port.
08-12-2011 05:33 AM
Looking at your config.
The only POTS dial-peer is not matching any port or trunk group. I think this is why the router is picking on the VOIP dial peers.
The DN making the call is:-
Can we try changing the config a little.
! Match Incoming PSTN calls to this peer
dial-peer voice 1 pots
description *** FOR INCOMING CALL MATCHING ***
direct-inward-dial
port 0/1/0:15
direct-inward-dial
port 0/1/0:15
Hope this helps
Alex
08-12-2011 07:31 AM
Hi Alex, thank you for response.
I'm sorry but it was only part of the config.
dial-peer voice 1111 pots
description ### internal PBX
destination-pattern [1-6]...
direct-inward-dial
port 0/1/0:15
direct-inward-dial
port 0/0/0:15
forward-digits all
But in the dial-peer 1111 i forgot the "forward-digits all" command maybe it was the case.
08-23-2011 02:30 AM
I have found the reason the high cpu load. It happenes when voice gateway accept a call from PBX or it may be any external call on the phone number(extension) that dont exists or assigned to ip phone on CUCM. How i can
solve that problem?
Thanks in advance.
08-23-2011 02:41 AM
If I may suggest, you can create translation pattern in CUCM and translate it to your desired extension. (ex. operator). Do this for any unassigned number or block.
Paul
