08-30-2012 01:43 AM - edited 03-16-2019 12:56 PM
We have a CUCM 8.6.2.22900-9 running, but this issue also occured when it was just version 8.6.2a.
Our CUCM seems to be rather slow, and when I open the RTMT it says we have high IOWAIT. To verify this, I went to the System Status and I see the IOWAIT is 35%. Now I take a look at the Process list in RTMT, and it seems the CiscoDRFMaster process is using up 30-35% CPU time.
To see what it's doing, I opened the Cisco DRF Master logs from the last 5 minutes. It appeared that this process is writing EIGHT 1MB logs every SECOND, and it's completely filled with this error:
2012-08-30 10:37:26,066 DEBUG [NetServerClient-krecucm01] - drfNetServerClient. Reconnect: Object InStream to be created
2012-08-30 10:37:26,066 DEBUG [NetServerClient-krecucm01] - drfNetServerClient.run, caught general exception from host: [krecucm01], message: null, cause: null
java.lang.NullPointerException
Does anyone know what this could be?
Ruud van Strijp
08-30-2012 05:49 AM
Dou you have any kind of traces enabled for the DRS services?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-30-2012 06:10 AM
Hi java,
Thank you very much, somehow logging indeed was enabled for this service. Disabling tracing caused the IOWAIT to drop back to below 1%.
However, this didn't solve the issue of the service running at high CPU usage. This is even 49% at the moment, I guess because it's still generating issues, just not logging those.
Ruud van Strijp
10-11-2012 01:02 AM
Last week we upgraded to CUCM 9.0.1-37, but I still have these issues. Our CPU load is very high (70%), all caused by the CiscoDRFMaster service running on 50% CPU usage.
Are there any logs I can check to see why the DRFMaster would use so much CPU?
Ruud van Strijp
