06-06-2012 06:57 AM - edited 03-16-2019 11:31 AM
I have a curios case with the hold and transfer features in cme and 3905 sip phones. There is not sccp phones.
The SIP SP give us a sip trunk with two headers, 3185840 and 3185860. I already setup the AA for both numbers.
Incoming Calls from SIP TRUNK.
When a called number is one of the headers, the transfer and hold works fine.
If the called number is another number using DID, 3185861 for example, the hold and transfer doesn’t work.
When the I pick up the phone, and press the hold (or transfer) , 3905 softkey the call is dropped. The calling party hears a busy tone.
The translation rule for the incoming dial-peer is simple, rule 1 /^.*\(....\)/ /\1/ , that rule just take the last four digits of the called number. The last four digits match with the phone extensions.
The attached debug has two scenarios:
Please I need some help, thanks.
06-06-2012 07:25 AM
Cause code 85 is a media negotiation failure. Sound like a possible codec mismatch. Do you have an MTP configured?
06-06-2012 12:27 PM
I have configured conference resources.
no xcode. May be the problem is a mistmatch between the codec listed in the voice class codec
and the dspfarm profile 1 conference:
voice class codec 1
codec preference 1 g711ulaw bytes 160
codec preference 2 g729br8 bytes 20
codec preference 3 g711alaw bytes 160
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum conference-participants 8
maximum sessions 1
I will change that config and I will let you know.
Thanks.
06-08-2012 12:06 PM
Solved with :
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
g729 annexb-all
