hold/transfer stop working
miket
Level 5
Level 5
I have an issue on CUCM 10.5 and 7841 sets with latest firmware. The hold/transfer stop working and you need to reset the phone or unplug it to restore functions.  I have the latest firmware on the sets and it still is happening. Anyone see this lately and has resolved it?
5 Replies 5
You must be running into bug CSCun65437. Find the below link helpful.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCun65437/?referring_site=bugquickviewredir
Abhay
Rate all helpful posts !!!
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Brandon Buffin
What firmware version are you running? Seems related to this bug:
Brandon
I am running sip78xx.11-7-1-17 I seen the two bugs and wonder if still an issue with some firmwares
Thanks for the reply
Seems to be an exact match with the bug, would advise you to open up a TAC case so that ES can be published for you.
Abhay
Abhay Singh Reyal
I have a TAC case open. I tried to use a downlevel ES firmware but no luck.
I will update when I have a fix
