Home Lab questions
redbull88
Hello all,
I have a a 2911 ISR I am using as my home router. I have recently come to possess a handful of 7962 phones. Working a day job as a LAN support team member for a large company I am somewhat familiar with Routers but not as well as switches.
I am currently a student studying and trying to learn more about these systems and want to build my own VoIP lab at home using the equipment I currently have. Spending only a few hours on the topic I have tried to figure out what is needed to run CME on my 2911 Router.
Browsing different documentation and web pages from Cisco for different offerings I have no definite answers. At the least you could say i'm a bit overwhelmed with lots of information I don't fully understand. Which is exactly why I am here on the forum seeking advice from others who may have valuable information I am lacking which would help me achieve my end goal.
Any help that can be provided will be greatly appreciated. Thank you for your time!
luis_cordova
Hi @redbull88
In summary
Router
Router(config)#interface f0/0 <- to switch
Router(config-if)#no shutdown
Router(config)#interface f0/0.10
Router(config-subif)#encapsulation dot1q 10
Router(config-subif)#ip add 192.168.0.1 255.255.255.0
Router(config)#ip dhcp pool voice
Router(dhcp-config)#network 192.168.0.0 255.255.255.0
Router(dhcp-config)#default-router 192.168.0.1
Router(dhcp-config)#option 150 192.168.0.1
Router(config)#telephony-service
Router(config-telephony)#max-ephones <1-42>
Router(config-telephony)#max-dn <1-144>
Router(config-telephony)#create cnf-files
Router(config-telephony)#ip source-address <CME ip> port 2000
Router(config)#ephone-dn <1-288>
Router(config-ephone-dn)#number <telephone number>
Router(config)#ephone <1-96>
Router(config-ephone)#mac-address <phone MAC>
Router(config-ephone)#type 7962
Router(config-ephone)#button 1:1
Switch
Switch(config)#vlan 10
Switch(config)#interface f0/1 <- to router
Switch(config-if)#switchport mode trunk
Switch(config)#interface f0/2 <- to phone
Switch(config-if)#switchport mode access
Switch(config-if)#switchport access voice vlan 10
Thank you for the reply. I have a specific subnet created for my voice traffic. Switch and Router configuration of my existing network have already been created. When trying to use the "telephony-service" command from global config it's not taking the command. Would the CME software have to be installed on the system separate from the IOS image? If so, how would I go about doing so?
Jaime Valencia
You would need to enable the UC license on the ISR, and once it has been enabled, you can refer to the CME administration guide for all the tasks related to IP Phone configuration
https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
java
if this helps, please rate
Hello, Thanks for the reply.
I'm not seeing that the UC license is enabled on the system. Nor would I have a clue about how to achieve this. I'm also assuming anything more than an evaluation of this feature would cost an arm and a leg?
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTX1839ALAX
3 Gigabit Ethernet interfaces
2 Serial interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2911/K9 FTxxxxxxxxx
Suite License Information for Module:'c2900'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
datak9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc None None None
data None None None
CiscoSysRtr#
