Host Not Found - Extension Mobility problem
sayeedibrahim
I have enabled extension mobility.
I understand that the service is configured properly as some users are able to login/logout successfully and when I check the URL in the settings of their IP Phones it displays the IP address of the server.
For some users, when I press the service button it displays message "Host Not Found" and when I check the URL in the settings of their IP Phones it does not display the  address of the server.
I have already tried the common mentioned solutions but no luck.
1. I have already made changes in Enterprise settings and replaced the CCM Hostname with IP Address.
2. I have added an entry in DNS server
3. Re-configured the service
4. Restarted the IP Phones, services [TFTP, Extension Mobility]
5. Rebooted the server
The only thing I missed out on was changing the hostname to IP address.
When i go to System---Server ---Find --- it displays the hostname. I am afraid of loosing service if I change from Hostname to  IP. The application itself warns from doing the same. I am managing the server remotely and have no technical assistance at the site.
Appreciate guidelines from all you techies out there.
25 Replies 25
Joshua Warcop
Level 5
Level 5
I didn't catch what models phone you have - but make sure you are telling the phones what domain to use when they do a DNS lookup.
If your using an IOS device for DHCP - make sure you have in your "ip dhcp pool Voice" a "domain-name mydomainx.com"
Name resolution should work fine and my personal recommendation is to stick with name resolution and use the CUCM server name instead of IP address.
Hello Everybody
The strange thing is that Services are working for some users and not for all users.
Check attached file and take at the loads info.
IP Phone with DN 9556 has all the services working while the other IP Phone with DN 9669 does not have the services running.
Those two phones are running completely different firmware - the non working one has not upgraded.
Can you screen grab the 'network configuration' page on the phones? It looks like one has not been able to upgrade for some reason. Do they both have the same TFTP server configured? Can they be PINGed from the TFTP server?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I do not have a seperate TFTP server.
Both phones are using CCM as the TFTP server.
On the IP Phone with old firmware I tried basic reset [erase option from settings menu on the phone]  but no changes so i tried factory reset but now this phone keeps rebooting.
Here is the network config info:
1. IP Phone with services working fine
DHCP Server10.65.56.2
BOOTP ServerNo
MAC Address00070E361E98
Host NameSEP00070E361E98
Domain Name
IP Address10.65.57.46
Subnet Mask255.255.255.0
TFTP Server 110.65.57.4
Default Router 110.65.57.1
Default Router 2
Default Router 3
Default Router 4
Default Router 5
DNS Server 110.65.56.2
DNS Server 210.65.50.22
DNS Server 310.65.50.21
DNS Server 4
DNS Server 5
Operational VLAN Id2
Admin. VLAN Id
CallManager 1RSF-S01-C02-B01-UCM-1
CallManager 210.65.57.4 Active
CallManager 3
CallManager 4
CallManager 5
Information URLhttp://10.65.57.4:8080/ccmcip/GetTelecasterHelpText.jsp
Directories URLhttp://10.65.57.4:8080/ccmcip/xmldirectory.jsp
Messages URL
Services URLhttp://10.65.57.4:8080/ccmcip/getservicesmenu.jsp
DHCP EnabledYes
DHCP Address ReleasedNo
Alternate TFTPNo
Forwarding DelayNo
Idle URL
Idle URL Time0
Proxy Server URL
Authentication URLhttp://10.65.57.4:8080/ccmcip/authenticate.jsp
SW Port ConfigurationAuto Negotiate
PC Port ConfigurationAuto Negotiate
TFTP Server 2
User LocaleEnglish_United_States
Network LocaleUnited_States
Headset EnabledYes
User Locale Version4.2(3)
Network Locale Version7.1.0.1(3)
PC Port DisabledNo
Speaker EnabledYes
Group ListenNo
GARP EnabledNo
Video Capability EnabledNo
Voice VLAN EnabledYes
Auto Line Select EnabledNo
DSCP For Call ControlCS3
DSCP For ConfigurationCS3
DSCP For ServicesDefault
Security ModeNon Secure
Web Access EnabledYes
Span to PC PortNo
PC VLAN
CDP: PC PortYes
CDP: SW PortYes
2. IP Phone with " Host Not Found" problem
BOOTP ServerNo
MAC Address00070E165CA5
Host NameSEP00070E165CA5
Domain Name
IP Address10.65.57.42
Default Router 2
Default Router 3
Default Router 4
Default Router 5
DNS Server 4
DNS Server 5
Admin. VLAN Id4096
CallManager 3
CallManager 4
CallManager 5
Information URLhttp://CISCO-CALLMANAG/CCMCIP/GetTelecasterHelpText.asp
Directories URLhttp://CISCO-CALLMANAG/CCMCIP/xmldirectory.asp
Messages URL
Services URLhttp://CISCO-CALLMANAG/CCMCIP/getservicesmenu.asp
DHCP EnabledYes
Alternate TFTPNo
Forwarding DelayNo
Idle URL
Idle URL Time0
Proxy Server URL
Authentication URLhttp://CISCO-CALLMANAG/CCMCIP/authenticate.asp
TFTP Server 2
Headset EnabledYes
User Locale Version4.1(3)
Network Locale Version4.1(3)
PC Port DisabledNo
Speaker EnabledYes
GARP EnabledYes
Span to PC PortNo
PC VLAN4096
Any hands on experience how i can upload new firmware on the CCM and IP Phone.
You don't need new firmware on the CCM; you need to make sure the phones on your network that have not upgraded can access the firmware you already have.
Pls check the below msgs that i see under the Device Logs - Debug Display
11:23:32a 24: Name=SEP00070E1626A4  Load= 7.2(1.0S) Last=Phone-Reg-Rej11:23:32a  24: Name=SEP00070E1626A4 Load= 7.2(1.0S) Last=Phone-Reg-Rej11:23:39a 6: Name=SEP00070E1626A4 Load=  7.2(1.0S) File Not Found11:23:40a  31: Name=SEP00070E1626A4 Load= 7.2(1.0S) File Auth Fail:  SCCP11.8-5-2SR1S11:23:40a  24: Name=SEP00070E1626A4 Load= 7.2(1.0S) Last=Phone-Reg-Rej
Looks like you have a load that falls foul of the problem listed here:
https://supportforums.cisco.com/message/3032276#3032276
https://supportforums.cisco.com/message/3050219#3050219
Try upgrading them to an interim version of firmware as discussed in those posts, and then upgrading to 8-5-2SR1S.
This is noted in the release notes for that firmware:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_2/english/release/notes/7900_852SR1.html#wp164599
Aaron
Please rate helpful posts...
I have opened a TAC case and they suggested the same like you Aaron.
I will update once they solve the problem.
Thanks!
All services are now working on the ip phones after upgrading the firmware
All available IP phones had old firmware version 7.x
The new Call Manager 7.1 had phones firmware 8-5-2SR1S
I uploaded SCCP11.8-2-2SR3S on the CCM . IP phones did an auto upgrade to 8-2-2SR3S
Then changed the default device firmware back to 8-5-2SR1S and this time ip phones upgraded to the latest version a/v on the system
Thanks all for the support.
Thanks Aaron,
it also helped me, as the telephone was not used for a while and the firmware of cucm has been upgraded meanwhile. I have done a factory reset on the phone, took the new firmware and it worked. Thank
