04-29-2012 12:55 PM - edited 03-16-2019 10:53 AM
Can someone help to do a backup of CM 4.2
04-29-2012 05:08 PM
You need to install BARS application on the CM Publisher, download the latest BARS install it, point to a network share and off you go. Search CCO for BARS for more details if you need to, but it is pretty trivial.
HTH,
Chris
04-30-2012 05:33 AM
Hi Miguel,
Just to add a reference to the good tips from Chris (+5 "C-Man!)
Cisco IP Telephony Backup and Restore System (BARS) Administration Guide, Version 4.0(12)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bars/4_0_12/ag-4012.html
Here is the Software Download path
Unified Communications Manager/CallManager Backup and Restore System (BARS)-4.0(15)
Cheers!
Rob
