Hello ,
Caller ID name is sent by our telco ( IE Facility ) and we want to block this on the IP Phone. The Gateway is controlled by mgcp.
All the checkboxes under "PRI Protocol Type Spezific Information " are unchecked .
Se0/0/1:15 Q931: RX <- SETUP pd = 8 callref = 0x7100
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18382
Preferred, Channel 2
Display i = '123456 123456' # we want block this number
Date/Time i = 0x0C061D0C2824
Date (dd-mm-yr) = 12-06-29
Time (hr:mnt:sec) = 12:40:36
Under MGCP endpoint config you can choose to change or block calling/called name/number. Just adjust as you want those parameters.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
