How can I change the SIP port to 5070 in a cisco 2800?
mae45674-paetec
Hello Guys:
I have a cisco2800 that is going to connect to a SBC to registar using port 5070. Unfortunately, I don'y know the process to change the sip port to 5070, so far, the SBC is receiving the registar message on port 5060.
Thank you.
Martin.
2 Accepted Solutions
mae45674-paetec
Never mind, I found the answer by myself.
Thank you.
It helps to include the answer in case others find this thread in a search result.
https://www.cisco.com/c/en/us/td/docs/ios/voice/command/reference/vr_book/vr_l1.html#wp1036440
voice service VOIP
sip
listen-port
mae45674-paetec
Thank you.
voice service VOIP
sip
listen-port
Thank you Jonathan, I appreciate it.
