05-07-2013 11:24 PM - edited 03-16-2019 05:12 PM
I can join the conference directly:
Dial the conference phone number, dial the conference ID #, etc.
I want to do it with one quick key on my phone. How can I program this sequence?
05-08-2013 06:27 AM
Start by mentioning what call control system you use and version.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-08-2013 09:58 AM
I don't know. Where is it can be found?
05-08-2013 10:00 AM
If you're an end user, you should engage with your local IT team for this request.
This is not something that could be done on the phone itself.
java
