How can i disable silencesupp on AS5300 with G729r8
tausiifexpert
I want to disable silence suppression.
i am using G729r8 codec, but some how my calls are failing and my far end carrier wants me to disable silence suppression.
This is my H323 dial-peer
dial-peer voice 11 voip
description *****TEST********
destination-pattern 00T
translate-outgoing called 7
session target ipv4:192.168.10.1
I will be really thankful if someone help me
Thomas Dominic
Hi Tausif,
You need to give the command
no vad
under the dial-peer
Thomas
Thomas Dominic
Hi Tausif,
no vad
under the dial-peer
Thomas
Thanks alot Thomas, you are superman.
Best wishes
