how can I do dynamic dn routing through ils in 9.1.2?
hxmengmetro
Hi All,
I know this dynamic DN routing through ils is supported in 10 but we don't want to upgrade right away. Is there any work around to get it work through ils in 9.1.2? Like adding a numeric uri for user to get URI routed through ils over SIP trunk to SME. I haven't tried yet.
Ideas?
Thanks!
Lou
yahsiel2004
Level 7
Level 7
No you would have to upgrade. If you assign the users extension as a numerical URI, it's still a URI and you would dial the number as 1XXX@yourdomain
Yosh
HTH Regards, Yosh
hxmengmetro
Anyone? Thanks.
Lou
yahsiel2004
Level 7
Level 7
Yosh
HTH Regards, Yosh
Thanks Yosh. So my only way to do dynamic DN routing with 9.1.2 is CCD/SAF, right?
Yup! until you upgrade :/
Yosh
HTH Regards, Yosh
