12-27-2013 09:07 AM - edited 03-16-2019 09:01 PM
here is my situation.
Let say I own 777-777-1111. if someone called 777-777-1111, it'll route to my cucm and I need it to reroute to an external number that I don't own, let say it's 666-666-1111. And if that fails, it'll go to an external number 666-777-1111. Is if someone calls my number, how do i redirect to another number and have a backup number for that?
Right now i have a hunt pilot 1111 that points to dn 2222 and 3333. 2222 forwards to 666-666-1111 and 3333 forward to 666-777-1111. the problem with hunt pilot is that calls are not forward. it'll reach the hunt pilot 1111 and dial directly to 2222 and 3333. 2222 and 3333 doesn't forward the call. If i call 2222 and 3333 directly then call forwarding takes place.
using CUCM 8.5, Unity 8.5
12-27-2013 09:31 AM
That's expected to happen, any call forward behavior is ignored if the call arrives via a hunt pilot. That's WAD.
You would need to configure SNR for that scenario to happen.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-27-2013 01:39 PM
If I were to go the SNR route, how would I do it without using the a physical phone? I couldn't do through CTI route point or CTI port.
