How can I make calls through second priority device
lana1
I have Route Group assigned to 2 Route Group Members and as ordered by priority calls will go to  first E1!!
My question is how can I send call through second E1!
Needed for torubleshooting purposes!
Thank you
2 Accepted Solutions
Hi @lana1
You can configure a new Route Pattern with a new partition, this partition should only be included in the CSS of the device you're making the test calls from.
This Route pattern will point to a new Route List, which points to a new Route Group that only has the specific slot you wanna send the call to.
Outbound calls for other devices will not be affected, since their CSS will not have the partition of the newly configured RP
As @eyalraba wrote, if you want to just use one E1 for testing, you have to build a different call routing structure.
12 Replies 12
b.winter
Just switch the order in the Route group^^ Or set the algorithm to "Circular"
Thanks for reply!
No, I don't want to change the priority!
In traditional telephony, ex. MD110 there was possibility to make call through specific slot!
I want to send call through second E1, for testing and troubleshooting!!!
Thank you
Hi @lana1
Done
Thank you very much!
lana1
Can I make additional question here!!!
Debug in Cisco 4331outcome is in Hexadecimal!!
How to chnge in Decimal!!!
Thank you!!
Can you share an example output, of what exactly to you mean?
Pls see below!!
I have this problem now in all gateway endpoints!!
005749: Jun 5 08:42:57.297: ISDN Se0/1/0:15 Q931d: srl_send_l3_pak:
source_id = CCM MANAGER 0x0003, dest_id = Q.921 0x0000, prim = DL_DATA_REQ 0x0240
priv_len = 4 int_id = 0x0x7FCB1FCB8938 datasize = 29
005750: Jun 5 08:42:57.297: ISDN Se0/1/0:15 Q931d: data =
005751: Jun 5 08:42:57.297: 00007FCB1FCB89380000000302400400
005752: Jun 5 08:42:57.297: 00010000080200544508028090
005753: Jun 5 08:42:57.316: ISDN Se0/1/0:15 Q931d: srl_send_l3_pak:
priv_len = 4 int_id = 0x0x7FCB1FCB8938 datasize = 25
005754: Jun 5 08:42:57.316: ISDN Se0/1/0:15 Q931d: data =
005755: Jun 5 08:42:57.316: 00007FCB1FCB89380000000302400400
005756: Jun 5 08:42:57.316: 00010000080200545A
What debugs have you enabled?
If you're troubleshooting calls for ISDN connection, just run the command "debug isdn q931"
debug isdn q931 detail
rimishr2
If you don't want to change the priority, then change the distribution algorithm to Circular.
Hi rimshir
Thanks for your post!
But I already fixed with eyalraba and b.winter
