Enthusiast
FYI, this is not valid. If
If you use the command "set password user security" and you type in anything for the "old password" and you type the same thing in for "new password" it will say that "old and new password are the same" - therefore it's not checking it against the current security password.
The post that gorourke posted below however IS valid.
Re: There is no official way of
Hi niterid3r ,
The method you proposed is working and one of the BEST way to validate the security password of the system. I just want to add some test results as an evidence. I have personally tested this on my lab and also in the customer Environment.
***** This method is only for VALIDATING THE SECURITY PASSWORD. (i.e) The customer knows his security password but was unsure of whether it is correct or wrong ******
CUCM Version : 10.5.2.12900-14
Publisher CLI
login as: cucmadmin
cucmadmin@10.106.102.70's password:
Command Line Interface is starting up, please wait ...
Welcome to the Platform Command Line Interface
VMware Installation:
2 vCPU: Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz
Disk 1: 110GB, Partitions aligned
6144 Mbytes RAM
admin:
admin:show version active
Active Master Version: 10.5.2.12900-14
Active Version Installed Software Options:
cmterm-ata190.1-2-2-003.k3.cop
cmterm-ata190-qed.1-2-2-003.k3.cop
admin:
admin:
admin:
admin:
admin:set password user security
Please enter the old password: *************
Please enter the new password: *************
Old and New password are the same.Please use a password different from the existing one
I know my Security password and I gave the same one for both OLD and NEW PASSWORD when prompted. Since both were same , the system prompted me to enter a different one. This is evident from the result above.
HENCE PROVED ...
Thanks niterid3r for sharing the same.
Beginner
My results weren't quite as
My results weren't quite as advertised, so I thought I'd share.  Applies to CUCM 7.1.5.34063-1
This is what I found as the output when doing this trick, and guessing correctly the old password:
Please enter the new password: ******** <--cisco123
Reenter new password to confirm: ******** <--cisco123
The Security password has now been reset <-- (well, not really, keep going)
WARNING:
Please make sure that the security password on the publisher is changed first.
The security password needs to be the same on all the cluster nodes,
or the publisher and subscriber(s) will not communicate.
After changing the security password on a cluster node, please restart that node.
Continue (y/n)?y
Please wait...
Executed command unsuccessfully
BAD PASSWORD: it is based on a dictionary word
This is what I saw when my password guess was wrong:
WARNING:
Continue (y/n)?y
Please wait...
Password changed too soon
Beginner
Re: How can I validate a security password on CUCM 8.6?
I know this is an old thread, but recently had to find a way to get the security password for CUCM, CUC and CUIC in preparation for a restore and upgrade procedure. What we ended up doing is logging a TAC case. We were asked by the engineer to get the file /usr/local/platform/conf/platformConfig.xml and provide it to him. TAC was able to extract the security password from there and it worked.
You may follow the link to get all the details about password verification, change, methods etc.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/213527-changing-cucm-os-admin-and-security-pass.html
Pls. respond if this resolve the problem.
Liked it ?
Content for Community-Ad
July's Community Spotlight Awards
