how configure jabber android to cme 9.0 - router 2911?
YASITAERICK
I have a router 2911 and I want to configure jabber to android smartphone ? What write in the device name ? I really appreciate your help. Thank you.
6 Replies 6
Jaime Valencia
Jabber for Android is only supported with CUCM
System requirements
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/jabber/Android/8_6/Cisco_Jabber_Android_8_6_2_RN.html#wp46650
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
I have that information in the cme 9.0 ok
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(3)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 13-Jun-12 14:24 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
CME_HTC_LA_PAZ uptime is 12 hours, 1 minute
System image file is "flash0:c2900-universalk9-mz.SPA.152-3.T1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
voice register global
mode cme
source-address 192.168.2.1 port 5060
bandwidth video tias-modifier 900000 negotiate end-to-end
max-dn 50
max-pool 50
authenticate presence
authenticate register
authenticate realm cisco.com
hold-alert
tftp-path flash:
create profile sync 0009082271491446
voice register dn  4
number 412
allow watch
name Karoll Trujillo
label Karoll Trujillo
voice register pool  4
registration-timer max 720 min 660
id device-id-name SEP0C715D65DB07
session-transport tcp
type Jabber-Android
number 1 dn 4
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
And the document of cisco refer about jabber for android to cme 9.0, with that type of cellphone I want to try ?
FUNCIONA EN UN MINI GALAXY  +++++> ANDROID
Hola, hablas español?
Se que el tema es viejo pero yo recién intento hacer funcionar el cliente Jabber en Android. He podido registrar un par de teléfonos y logro hacer la llamada saliente, pero cuando me contestan no escucho al otro interlocutor, ellos a mi si.
Tuviste exito con tu mini galaxy?
YASITAERICK
CME 9.0 can integrate smartphone with SO  Android. I can register Andoid Mini Galaxy in CME 9.0
add new config
username 412 password 412
create profile
or
id mac 0C715D65DB07
then
create profile
