How do I determine number of licenses on my CallManager 3.3?
paul.m.phelps
Beginner
Beginner
How do I find the number of licenses for IP Phones, etc. currently on my CallManager 3.3? Thanks
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hi Paul,
In all CCM Versions prior to 5.x the licenses were "paper" only. There is no actual reference to be found via ccmadmin. If you do a search via Device>Phone>by each model type you will find the numbers to input in the License Calculator.
Hope this helps!
Rob
8 Replies 8
r.stockton
Beginner
Beginner
The licences are tied to the phone. On previous versions of CallManager, when you purchased the phone, you got the licence. Are you trying to determine your licence count for an upgrade to 6.x?
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
reach licensing@cisco.com
they will give you a spreadsheet you need to fill so they can generate the license for a 5.x or 6.x version
DLUs per phone are different between versions so make sure to tell them which version you will go
java
if this helps, please rate
java
Yes. We are. Thanks
Isn't there a way to look on the CallManager 3.3 Administrator web interface to see how many licenses are currently on the CM?
Rob Huffman
Hi Paul,
Please find the attached License unit Calculator. This will help determine the number of phone licenses that correspond to your current number of IP Phones.
Hope this helps!
Rob
Rob Huffman
Hi Paul,
Hope this helps!
Rob
Thanks Rob!
Rob Huffman
Hi Paul,
You are most welcome my friend :) Best of luck on your upgrade.
Take care,
Rob
Recognize Your Peers
