How do I have CUE on this router?
Michael Durham
Level 4
Level 4
I bought a used 2911 router that has UC license on it.  The previous owner never accepted the US license but I have.  I have been working with CME 8.6 for some time now and I know if you need voicemail, you need an AIM or NM CUE module.
Well... I did a very basic config using part of one from my 3945 router just to get it going.  The config has settings for voicemail but I NEVER expected for it to work.
This 2911 router does not have a ISM or SRE module installed.  Yet, when I let a phone go unanswered, it went to voicemail.  You can imagine my surprise!!!
I figured out the default password which is 1234; something that I did not set up.
I have researched the web and cannot find where they added a voicemail solution to CME by default.  So... where is this voicemail service coming from?  It defiantly is CUE.
Below is everything about my 2911 router.
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.7(3)M, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 27-Jul-17 02:37 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
Router uptime is 24 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.157-3.M.bin"
Last reload type: Normal Reload
Last reload reason: power-on
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTXK
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
2048256K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2911/K9 FTXK
Suite License Information for Module:'c2900'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
datak9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data datak9 Permanent datak9
License Store: Primary License Storage
StoreIndex: 0 Feature: datak9 Version: 1.0
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
StoreIndex: 1 Feature: ipbasek9 Version: 1.0
StoreIndex: 2 Feature: uck9 Version: 1.0
StoreIndex: 3 Feature: securityk9 Version: 1.0
License Store: Built-In License Storage
StoreIndex: 0 Feature: securityk9 Version: 1.0
License Type: EvalRightToUse
License State: Inactive
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
License Priority: None
StoreIndex: 1 Feature: uck9 Version: 1.0
StoreIndex: 2 Feature: datak9 Version: 1.0
StoreIndex: 3 Feature: FoundationSuiteK9 Version: 1.0
License State: Active, Not in Use, EULA not accepted
StoreIndex: 4 Feature: AdvUCSuiteK9 Version: 1.0
StoreIndex: 5 Feature: ios-ips-update Version: 1.0
StoreIndex: 6 Feature: SNASw Version: 1.0
StoreIndex: 7 Feature: cme-srst Version: 1.0
Evaluation period left: 8 weeks 3 days
Period used: 42 minutes 41 seconds
Transition date: Aug 02 2019 19:47:40
License Count: 20/0 (In-use/Violation)
License Priority: Low
Directory of flash0:/
4 -rw- 111045500 Sep 11 2017 10:47:18 +00:00 c2900-universalk9-mz.SPA.157-3.M.bin
5 drw- 0 May 30 2019 12:26:22 +00:00 PhoneFiles
93 drw- 0 May 30 2019 12:26:26 +00:00 Ringtones
127 drw- 0 May 30 2019 12:26:36 +00:00 Audio
129 drw- 0 May 30 2019 12:26:38 +00:00 GUI
NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: FTX1603AKZK, Hw Revision: 1.0"
PID: CISCO2911/K9 , VID: V05 , SN: FTXK
NAME: "3rd generation two port FXS DID voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "3rd generation two port FXS DID voice interface daughtercard"
PID: VIC3-2FXS/DID , VID: V02 , SN: FOCM
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16 , VID: V01 , SN: FOCT
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC , VID: V04 , SN: DCK
And where does DN 5000 point to?
java
if this helps, please rate
Jaime Valencia
Look at your configuration, where does the VM config points to?
java
Other than pointing to extension 5000, there is no VM config. There is no running service engine either.
Is a basic VM built into CME 12.0? or one of the license packs this router has?
java
Man do I feel dumb.
dial-peer voice 5000 voip
description Dial-peer to the Voicemail System"
destination-pattern 5000
b2bua
session protocol sipv2
session target ipv4:192.168.200.10
dtmf-relay sip-notify
codec g711ulaw
no vad
192.168.200.10 is another test router that does have an AIM card. I was getting VM from the wrong router. Changed to 192.168.201.10 and now no VM.
That is what I get for snagging configs from one router to use on another one. lol
Thanks for your help!
