How do I monitor the number of voice calls on my voice gateways?
pjwhitby_2
Beginner
Beginner
Hi all,
I have a 3845 with 4 x 2-port E1 VWICs, each port contains an ISDN30 circuit, therefore I have 240 voice channels connected.
How can I monitor the total number of voice channels currently in use, preferably via SNMP monitoring of the 3845? We also run LMS and are trialing the CUOM suite.
For example, if I use the command
show voice call status | i active
I get the response
239 active calls found
now in an ideal world :-) this figure, 239, is stored somewhere I get read via a SNMP poll?
ronpatel
Collaborator
Collaborator
HI
See if cvCallActiveDS0s  can help you.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
that seems to give inbound call volume only, is that to be expected?
for example, and I need to do this quickly
cvCallActiveDS0s gives me a count of 186
show voice call status | i active gives me a count of 191
show isdn active | i Out gives me a count of 4
and a call could have started or ended during the time I entered all commands, so I had 187 inbound calls and 4 outbound?
It shows "The current number of DS0 interfaces used for the active calls." It should show all type of calls.
I am assuming you are running 12.4 T release for this.
Ronak patel
we are running
c3845-ipvoicek9-mz.124-24.T4.bin
Its just that whenever I check the SNMP figure is always not a correct indication of the number of active calls, we are also running a full UCCE environment, but I cant see how that would impact the numbers?
I just tried it again,
SNMP reads cvCallActiveDS0s as 186
show voice calls status | i active reads 194
show isdn active | i Out reads 8 and show isdn active | i In reads 186
any ideas? coincidence?
