How do I setup voicemail in UC520
stuv
Hi there
I have setup the UC520 for most call processing tasks and one of the things that are pending is voicemail.  When I dial 500, the number just beeps 4 times a second.
TPOC-UC520#sh run | be dial-peer voice 2000
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 500
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711alaw
no vad
ephone-dn  13  dual-line
number 204 no-reg primary
label 204
description 204
name 204
call-forward noan 500 timeout 10
ephone  27
device-security-mode none
mac-address 001A.4B68.2D14
username "nocadmin" password password
type CIPC
button  1:13
ephone-27[26] Mac:001A.4B68.2D14 TCP socket:[1] activeLine:0 REGISTERED in SCCP ver 15/9
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:10
IP:172.16.1.3 45242 CIPC  keepalive 31 max_line 8
button 1: dn 13 number 204 CH1   IDLE         CH2   IDLE
Preferred Codec: g711ulaw
Username: nocadmin Password: password
22 Replies 22
Try the following change
destination-pattern 500...    (assuming your dial plan is three digits)
I take that back, adding the dots won't help.
It would be interesting to see the debug ccsip messages and debug voice dialpeer though
b2bua
codec g711alaw
TPOC-UC520#sh run | include destination-pattern 500
TPOC-UC520#
no vad
Remove this from the config "voice-class sip outbound-proxy ipv4:10.1.10.1", and I would like to know that you are getting to calling into the voice mail and also how are you doing the calls.
Change codec to "codec g711ulaw" instead of g711alaw.
Brandon
Strip the config down to this and change the last line from alaw to ulaw.  Unless Cisco has recently changed it CUE only runs ulaw
codec g711alaw
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/CP_CIPExpress/cipce21.html
Cool, I am able to access it now!!!!!!
Which ID and pin is it asking for now?
The ones that you configure under the inicial setup the first time that you access the GUI.
