04-13-2012 11:28 AM - edited 03-16-2019 10:38 AM
I have a CUCM Server installed in a UCS C200. UCS it is connected to the LAN. Someone has given me a E1 connection (two RJ45 - Coaxial) for communication to the Telephony Central.
Where should I have to connect this E1 to the CUCM?
04-13-2012 11:38 AM
If you're asking about a voice E1 you do not connect anything into CUCM, you need an ISR with an E1 card and PVDMs.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
04-13-2012 11:43 AM
Ok. you are saying that I must have a Router ISR with a wic E1 in the same LAN that the CUCM and then. What do I have to configure in both for to UP the Calling to Outside????
04-13-2012 11:46 AM
Completely depends on what protocol you want to use.
There are guides for both MGCP and H323 on CCO.
java
04-13-2012 11:50 AM
In this case I'd like to use H323. But I do not what is CCO? What's the link?
Are there some useful PDFs for this request?
Thank you in advanced.
04-13-2012 12:00 PM
CCO = www.cisco.com
There are plenty more links on CCO if you take some time to search.
java
04-13-2012 12:39 PM
Carlos:
As javalenc mentioned you will need a Cisco ISR with the following cards:
- E1 vwic
- PVDM memory: sizing depending on the codec used and the amount of simultaneus call needed in the E1 - (Max 30)
For the E1 you will need to find our some info from the other side:
- Framing
- Linecode
- Time slots
- Clock source
If you want to avoid to use an ISR you can use a E1 gateway with a SIP trunk to the CUCM.
Best Regards
Marcelo Czerewacz
