07-02-2015 11:20 PM - edited 03-17-2019 03:31 AM
Hi all,
We have 8945 series phones
We use CUCM 9.1
There is a reporting request such as to monitor the missed calls percentage on phone sets monthly? Do you recommend any solution fo that?
Thanks in advance.
07-03-2015 01:18 AM
You can pull the CDR report and then check the duration of the calls (zero duration calls) and calculate the percentage.
Make sure you enable 'CDR enabled flag' and 'CDR Log Calls with Zero Duration Flag' on all servers where CCM service is enabled.
Atul
07-03-2015 01:34 AM
Hi Atul,
The request is, every person should check his own missed call percentage. For exp: my directory number is 1111, when i press a button I should see a missed call percentage of my directory number/ or user.
07-03-2015 04:14 AM
That's not natively possible on CUCM or phone level. I haven't heard of any 3rd party product as well that can achieve this. Probably someone else would like to comment here.
-Atul
