how many devices does CUWL Standard support?
yun zhang
Hi guys
 I have a question that regarding cuwl std license , I found document from cisco that describer CUWL Standard : supports advanced (voice and video) call control features including desktop and mobile with maximum of two devices per user.
but in same document in another table the uwl std license support 10 devices  cuwl pro also support 10 devices
so  my question is which statement is correct ?
thanks
zy
HARIS_HUSSAIN
It will support 10 devices per user. Enhanced Plus UCL will support 2 devices.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Hi Haris
thanks for your reply and below captured from cisco document , it shows maximum of two device per user for CUWL STD model
Any advices?
Zy
George Sotiropoulos
Hello Yun,
CUWL Standard license provides rights to advanced (voice and video) call control features including desktop and mobile and up to ten devices per user.
George
Hope the above helps,
gsotirop
