i am not aware of a hard max value, altghough there most likely is one.
the question is though if you have some of your users part of a large number of hunt/line groups, then really is native cucm a suitable solution for you, because you might want to consider sticking for instance an IVR in place, instead of using all individual hunt pilots. (just a thought).
Please remember to rate useful posts, by clicking on the stars below.
