We prepared 2851 router to test multi-tenant MTP.
But, we have an issue on this implementation.
Cisco TAC mentioned, this will not work on VRF environment.
Is there any other way to put multiple MTP groups on single router in VRF environment?
These are comments from Cisco,
"Your interfaces that you bind to in the ccm groups are members of different VRF's. This is not supported."
"SCCP using a VRF in any case, appears to be unsupported. Global VRF only."
