how the to know the OS version of CMS
networkexpert
Dear all ,
I have requested to tell the OS version of cisco CMS
Build version2.6.1
form the VSphare I can't also see the os version as attached
would you please advice from where i can get that?
Jaime Valencia
I don't believe that is exposed or documentes anywhere as it's a closed system.
java
if this helps, please rate
Thanks for your reply
so how to get the this information
only the Linux version of Cisco application!!
