10-11-2018 01:00 PM - edited 03-17-2019 01:34 PM
Hi all,
I have to check our license usage, but i do not have admin password since the previous person did not leave the password. I am a supper user in CUCM, as i know, reset password with recovery CD is a way, but i do not want to take risk. Is there another way to check the license from PLM?
Thanks.
Solved! Go to Solution.
10-11-2018 01:54 PM
No, you can get some basic info via CLI, but you don't really see the license usage there.
co-res PLM uses the same user as CCMadmin, and you can find out if any other users have PLM access via CLI.
10-11-2018 01:54 PM
10-12-2018 01:14 PM
10-12-2018 01:38 PM
OK, then you will need to regain CLI access to then find out which users have PLM access.
10-18-2018 08:28 AM
Thanks Jaime, Just confirm does a independent PLM need the same username as ccmadmin? How to check from CLI which users have the privilege to access a independent PLM?
