08-12-2012 10:45 PM - edited 03-16-2019 12:40 PM
We had install CUE 8.6 and it is working with Evaluation license, now we upload the permanent license and reload the CUE, but still the permanent license shows not activated and the CUE is working with Evaluation only.
The screen print and sh command are attached, could please let know how to activate the permanent license.
Solved! Go to Solution.
08-13-2012 07:09 AM
Hi Bala,
I'm pretty sure this is your issue here
Have a look at the actual command description. You need to list the name of the license feature (high)
that you want to change to "low"
So for example;
license modify priority VMIVR-PORT high or
license modify priority VMIVR-VM-MBX high
this should list the VMIVR-PORT or VMIVR-VM-MBX "evaluation" license so that you can change it to low
once you re-boot the higher rated permanent licenses should show active/in use
To modify the license priority information, use the license modify priority command in Cisco Unity Express EXEC mode.
license modify priority feature name {high | low}
# high | # Sets the license priority level to high. |
# low | # Sets the license priority level to low. |
None.
# Cisco Unity Express Version | # Modification |
# 7.1 | # This command was introduced. |
This commands enables you to modify the license priority level. This command lists all the expiring licenses that are available for the specified feature and you can change the priority level to be the highest for the selected license.
The following example shows how to change the license priority level:
se-10-0-0-0# license modify priority TCV-USER high
Feature: TCV-USER
Index: 1 License type : Evaluation
Lock type : Locked
License Count : 2
License Priority: Low
Are you sure you want to modify priority? (yes/[no]): yes
Note The application will evaluate the changes in the next reboot.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/Command/l_cmds.html#wp1031346
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
08-13-2012 01:47 AM
Reload CUE.
Please do not use attchments for simple text.
08-13-2012 07:09 AM
Hi Bala,
So for example;
None.
Feature: TCV-USER
Lock type : Locked
License Count : 2
Cheers!
Rob
08-14-2012 06:16 AM
The Voice Mail box licenses is active, but the VM-ports are in Evaluation mode, please help me how to activate the VMIVR-ports ?
The sh commands as below:
Diners-CUE8-6# sh license status application
voicemail enabled: 4 ports, 4 sessions, 30 mailboxes
ivr disabled, no activated ivr session license available
Diners-CUE8-6# sh software versions
Cisco Unity Express version (8.6.1)
Technical Support: http://www.cisco.com/techsupport Copyright (c)
isco Systems, Inc.
Components:
- CUE Voicemail Language Support version 8.6.1
Diners-CUE8-6#
Diners-CUE8-6# sh license in-use
StoreIndex: 0 Feature: VMIVR-VM-MBX Version
License Type: Permanent
License State: Active, In Use
License Count: 30 /30
License Priority: Medium
StoreIndex: 1 Feature: VMIVR-PORT Version
License Type: Evaluation
Evaluation total period: 8 weeks 4 days
Evaluation period left: 1 week 5 days
Expiry date: Sun Aug 26 13:12:16 2012
License Count: 60 /4
Diners-CUE8-6#
08-14-2012 08:27 AM
You need to contact licensing@cisco.com to obtain VMIVR-PORT licenses that come included with a CUE hardware purchase.
08-14-2012 10:02 PM
Many Thanks, got the Port license for Licensing team.
