ā03-30-2017 07:14 AM - edited ā03-17-2019 09:56 AM
I'm running CUCM 9.1.1.10000-11 in VMWare Workstation for my lab, Demo License. I want to use 8851 phones so will need to add the Dev Pack 9.1(2.16147) so they appear as an option to add a phone. Will I need to upgrade the cluster to 9.1.2 in order install the dev pack? Or, can I install the dev pack to the existing 9.1.1 version?
ā03-30-2017 07:23 AM
you need to do minor upgrade to 9.1.2
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-731667.html
regds,
aman
ā03-30-2017 07:28 AM
Hi there,
You are most correct! You can't install a 9.1.2 device pack on a 9.1.1 CUCM so you would need to upgrade to at least 9.1.2. If you upgraded to the latest 9.1.2 version support for the 8851's would be included already.
http://www.cisco.com/web/software/282074295/136762/cucm-readme-912su6.pdf
Cheers!
Rob
EDIT: +5 to my buddy Aman for his good tips and for his superior typing skills!
ā03-31-2017 05:34 AM
Thanks Rob. Will I need to get an Enhanced User Connect License (UCL) to use the 8851 phone, or will it work with a Demo license?
ā03-31-2017 05:54 AM
It will work with demo licence, but when demo licence expires you would need Enhanced license.
(Rate if it helps)
JB
ā03-31-2017 06:55 PM
IP phone would work with demo licenses for grace period of 60 days.
After the expiry of same, u need to purchase permanent licenses.
regds,
aman
