12-06-2015 01:34 AM - edited 03-17-2019 05:07 AM
hi dear all,
i am using cucm 9.1.1 in which no option add phone 8331.
please help me in instlation and configuration of this conferance phone. i am using this for the first time...
waiting for your kind response...
Shazeb
Solved! Go to Solution.
12-06-2015 04:53 AM
you can refer the link for installation
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/9_3_3/english/adminguide/CS38_BK_A8C4AC51_00_adminguide-8831/CS38_BK_A8C4AC51_00_adminguide-8831_chapter_011.pdf
regds,
aman
12-06-2015 02:07 AM
either you can try adding device pack or u can upgrade CUCM to 9.1.2
Please refer the link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_01.html
for firmware 9.3(3), u can add device pack cmterm-devicepack9.1.1 and for 10.3(1) firmware, u need to upgrade CUCM to 9.1.2 and add device pack cmterm-devicepack9.1.2
attached is snapshot from device pack .
after u add device packs, restart the server.
regds,
aman
12-06-2015 04:53 AM
regds,
aman
12-06-2015 02:34 AM
Dear amam ,
Thanks for the suggestion ill go for device pack.. can you also help me in installation and configuration 8331 please..
Thanks and regards.
Shazeb
12-06-2015 07:42 AM
I assume you mean 8831 vs 8331.
You add it just like any other phone in CUCM, and do nothing on the phone itself as it will by default get IP address and TFTP option from your DHCP server just like any other phone.
