How to associate Existing Users with Existing Phones by BULK
Yazen Alaa
Dear All
I have around 1000 Existing Users  and 1000 cisco phones in CUCM ver 7.5 , My Question how to associate the existing users with extisting phones by BULK , Step by Step if you can  ?
thanks and regards
Ayodeji Okanlawon
You can use BAT to do this....in BAT look for update users tab...open the tab and then look for the column device association...
Put your users in the users column and their corresponding devices in the device column...export the file as BAT..go to cucm , import the file...then go to bat, update users and select the file you have imported..
Please rate all useful posts
Dear Aokanlawon
thanks for your reply , do have file or link that showing me step by step the process ?
thanks
Don't be lazy..I have given you all the steps. In this field you must be willing to go the extra mile, that's how you distinguish yourself from your peers and make yourself proud.
