08-07-2015 01:53 AM - edited 03-17-2019 03:54 AM
I am trying to block caller id from calls generating from non Cisco phones connected to a PABX which connects to a H.323 gateways via an E1.
I have done the following to block calls but nothing is seeming to block it. Any advise what else I need to do?
On H.323 gateway have added these commands.
dial-peer voice 1000 voip
clid restrict
dial-peer voice 2000 pots
clid restrict
Also on the CUCM version 7
Under relevant route pattern > Calling Line ID Presentation as "Restricted"
Also under Device Gateway> Calling Party Presentation as "Restricted"
But still shows up with the DDI when calls are made from the phones.
Anything else I need to do?
Thanks in advance.
08-07-2015 04:31 AM
Hi Kaushik,
Can you add the following commands under the dial peer and check
clid strip
clid strip name
Manish
- Do rate helpful posts -
08-07-2015 07:10 AM
Hi Manish.
thanks for your reply.
I have added the following
clid strip name
clid strip
clid strip name
clid strip
still shows as the default provider CLID
08-07-2015 07:36 AM
Hi Kaushik,
This might be overridden by telco. Most of telcos will append the default CLID in case they receive invalid one. You can't do antything with it
08-11-2015 03:08 AM
Thanks all
Is there any way each phone can be configured such that the correct CLID is reflected when it is called from that phone?
08-11-2015 04:06 AM
Sure. But you need to speak with your telco to understand what format are they expecting such as 4 digits, 7 digits, E164, +E164, etc
Once you get this, you can configure digit manipulation on CUCM or gateway to reformat the caller ID as expected by telco
08-07-2015 08:26 PM
What do you in the debugs Is CLID restricted being from CUCM & VGW to provider. Just check in the debug taking debug isdn q931 if its Telco appending it then you can't control that.
br,
Nadeem Ahmed
08-08-2015 08:17 PM
Kaushik,
as nadeem justed take a quick debug isdn q931.
-Regards,
Kevin
