Highlighted
Beginner
how to Block Caller id for outgoing calls
I am trying to block caller id from calls generating from non Cisco phones connected to a PABX which connects to a H.323 gateways via an E1.
I have done the following to block calls but nothing is seeming to block it. Any advise what else I need to do?
On H.323 gateway have added these commands.
dial-peer voice 1000 voip
clid restrict
dial-peer voice 2000 pots
clid restrict
Also on the CUCM version 7
Under relevant route pattern > Calling Line ID Presentation as "Restricted"
Also under Device Gateway> Calling Party Presentation as "Restricted"
But still shows up with the DDI when calls are made from the phones.
Anything else I need to do?
Thanks in advance.
7 REPLIES 7
Highlighted
Hi Kaushik,Can you add the
Hi Kaushik,
Can you add the following commands under the dial peer and check
clid strip
clid strip name
Manish
- Do rate helpful posts -
Highlighted
Beginner
Hi Manish. thanks for your
Hi Manish.
thanks for your reply.
I have added the following
clid strip name
 clid strip
 clid strip name
 clid strip
still shows as the default provider CLID
Highlighted
VIP Advisor
Hi Kaushik, This might be
Hi Kaushik,
This might be overridden by telco. Most of telcos will append the default CLID in case they receive invalid one. You can't do antything with it
Highlighted
Beginner
Thanks all Is there any way
Thanks all
Is there any way each phone can be configured such that the correct CLID is reflected when it is called from that phone?
Highlighted
VIP Advisor
Hi, Sure. But you need to
Sure. But you need to speak with your telco to understand what format are they expecting such as 4 digits, 7 digits, E164, +E164, etc
Once you get this, you can configure digit manipulation on CUCM or gateway to reformat the caller ID as expected by telco
Highlighted
What do you in the debugs Is
What do you in the debugs Is CLID restricted being from CUCM & VGW to provider. Just check in the debug taking debug isdn q931 if its Telco appending it then you can't control that.
br,
Nadeem Ahmed
Br, Nadeem Please rate all useful post.
Highlighted
Participant
Kaushik,as nadeem justed take
Kaushik,
as nadeem justed take a quick debug isdn q931.
-Regards,
Kevin
Content for Community-Ad
FusionCharts will render here
