11-08-2021 02:02 PM
Hello!
How Can I block incoming call for specific calling ID in Call Manager 12.5? I am using MGCP gateway.
Solved! Go to Solution.
11-08-2021 02:23 PM
William Bell of the Chesapeake NetCraftsmen wrote up a wonderful how-to for this a bunch of years ago. He is using CUCM 8.6 as an example (which was current when he wrote it) but the technique holds just as true for current versions of CUCM. There used to be a doc written by him on Cisco's website as well (with the same technique) but I can't find that.
Cisco CUCM Blocking Calls by Calling Party Number (ID)
Maren
11-08-2021 02:23 PM
Maren
11-08-2021 03:14 PM
Hello Maren!
Thanks for your answer!
I tried that procedure but the version CUCM 12.5 doesn't have the option Route Next Hop by Calling Party Number.
11-08-2021 04:13 PM
CUCM 12.5 absolutely does have the Route Next Hop checkbox on Translation Patterns. Here is a screenshot of a 12.5 system in my lab:
Maren
11-08-2021 10:38 PM
This document by @dakeller outlines how to achieve what is asked about and from what I know is what others possibly have based their posts from.
Blocking Calls Based on Calling Party ID
11-08-2021 11:33 PM
11-08-2021 11:49 PM
The last option, aka on the voice gateway, does not work with MGCP. The gateway needs to be either controlled by SIP or H.323 for this to work.
11-09-2021 12:39 AM
11-11-2021 03:40 AM
