02-21-2013 07:17 AM - edited 03-16-2019 03:52 PM
I have an internal number 6001 that I want to prevent incoming external calls to be received on that line? How would I go about accomplishing this? I also have an MGCP gateway. Is it better to do it in callmanager or on the gateway? Whenever someone dials the full 10 or 7 digit number that point to that extension, I want it to drop if coming from the outside.
Thanks.
AB
02-21-2013 07:20 AM
Just move that DN to another partition and adjust the inbound CSS in the GW.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
02-21-2013 07:46 AM
I understand how the CSS points to the partition and then the gateway calls outbound, but how do I control calls inbound to the gateway?
02-21-2013 07:48 AM
As i mentioned, you configure the inbound CSS from the GW
java
02-21-2013 08:06 AM
The gateway incoming CSS is already set to internal. I've pointed the DN to the internal CSS also. But when I dial the 10 digit number of that DN, it still connected. How can I shut calls down to that number only?
02-21-2013 09:12 AM
You need to assign a new partition to the DN that is not listed in the internal CSS. Since internal CSS might also be used by your phones internally you may want to assign different CSS to GW so this way you can still reach the user from other IP phones but not from outside.
Chris
