06-20-2013 12:26 PM - edited 03-16-2019 05:59 PM
Hello Everyone,
I am trying to configure a CME v8.6
Everything works fine, but i got a requeriment;
i need to block calls using a code in just one phone extension. All calls in the rest of phones must be free
Anyone has configured something like that?
Thanks in Advance
Rolando Gutierrez
Solved! Go to Solution.
06-20-2013 03:36 PM
Please refer to this thread...The correct configuration ofr lpcor is there
https://supportforums.cisco.com/message/3780229#3780229
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
06-20-2013 01:12 PM
You can use Class of restriction to achieve this...Here is the link on how to configure this
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
06-20-2013 03:31 PM
Thanks aokanlawon,
yes, i am sure that cor list would be fine, but what the boss is asking, is a secret code, what i mean is, when the people try to make a call, prompt for a code, if isn't the correct, then drop the call...
I was reading and trying to configure FAC. but is not working...
aaa new-model
aaa authentication login default local
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
voice lpcor enable
voice lpcor custom
group 1 garita
group 2 general
voice lpcor policy general
service fac
accept general fac
application
package auth
param max-retries 0
param term-digit #
param passwd 12345
param abort-digit *
param max-digits 32
voice-port 0/1/0:15
lpcor outgoing general
translation-profile incoming 91-IN
ephone 6
lpcor type local
lpcor incoming garita
lpcor outgoing garita
device-security-mode none
mac-address abc.def.000.000
ephone-template 1
button 1:5
I think something i'm missing, but is the first time trying...
Somebody can tell me what is wrong??
Thanks in Advance
06-20-2013 03:33 PM
TTTTT#sh voice lpcor policy
voice lpcor policy general (group 2):
service fac is enabled
( reject ) garita (group 1)
( accept fac ) general (group 2)
the policy garita would ask for the code? and
the policty general would be free?
It is something like that?
06-20-2013 03:36 PM
06-21-2013 02:46 PM
So many thanks aokanlawon
Here it is my final config, it is working ok!
Just In case somebody could need it!
aaa new-model
aaa session-id common
voice lpcor enable
voice lpcor call-block cause invalid-number
voice lpcor custom
group 11 LocalUser
group 12 AnalogPhone
voice lpcor policy LocalUser
service fac
accept LocalUser fac
accept AnalogPhone fac
voice lpcor policy AnalogPhone
service fac
application
package auth
param max-retries 2
param passwd-prompt flash:pass.au
param abort-digit *
param passwd 12345
param term-digit #
param user-prompt flash:user.au
param max-digits 32
username 839382 password 0 9039
gw-accounting aaa
voice-port 0/1/0:15
lpcor incoming AnalogPhone
lpcor outgoing AnalogPhone
ephone 6
lpcor type local
lpcor incoming LocalUser
lpcor outgoing LocalUser
description "XXXXXX"
mac-address aaaa.bbbb.cccc
type X
button 1:X
end
Cheers!
06-21-2013 12:49 AM
You can use after-hours block with login PIN override.
06-21-2013 02:47 PM
Thanks Paolo,
i tried it too, but what i need is just block one extension
06-21-2013 04:31 PM
tonoguate wrote:
Thanks Paolo,
yes, you would configure all the other as exempt. There is more than one way to do what you want.
