10-13-2010 07:48 AM - edited 03-16-2019 01:19 AM
Dear All,
Need your help in this,
I wanted to block one perticular number, how to do that in cisco ip phone any idea would be great.
Can we block in CCM a perticular number?
AteeQ
10-13-2010 07:54 AM
Depends on what you want to do. If this is a PSTN call, you cannot block a specific call at the IP phone level. In this case, you would need to use an H323 configuration where you can configure a blacklist and block calls based on caller ID.
If you want to block User A from calling User B, you would need to leverage partition and CSS setup to do this - however, this is rarely done for one specific caller.
Hailey
Please rate helpful posts!
10-13-2010 07:56 AM
Take a look at the following links.
https://supportforums.cisco.com/docs/DOC-2907
https://supportforums.cisco.com/docs/DOC-1850
Hope this helps.
Brandon
