How to Block specific tel numbers in cisco call manager
janice.valencia
Our version is:
Cisco Unified CM Administration
System version: 11.5.1.10000-6
We would like to block 60 numbers in call manager. If someone can help us out that would be great. Thank you.
Jaime Valencia
I'll assume you mean incoming calls, if so, this topic has been discussed hundreds of times before in CSC, a quick search will provide you with all the information related to this.
For outbound calls, configure translation patterns and set them to block the calls.
java
if this helps, please rate
Hello, can we do the configuration without impacting the calls or without resetting anything?
I depends on your setup...but I recommend you if you're not sure to schedule all changes after hours.
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Search on google and you would find numerous discussions as per your requirement. Check the  below link for reference
https://www.google.co.in/search?site=&source=hp&q=block+numbers+in+cucm&oq=block+numbers+in+cucm&gs_l=psy-ab.3...4105.7551.0.7776.22.12.0.0.0.0.473.1293.3-1j2.3.0....0...1.1.64.psy-ab..19.3.1293.0..0.C4JgGpW3R5I
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
