How to build a new cluster and what to do if subscriber fail in cluster
RaushanKumarSingh75308
Frequent Visitor
Frequent Visitor
Hi All,
i have to build a new cluster from scratch could someone please share the steps or documents and
7 Replies 7
Frequent Visitor
Frequent Visitor
i have to build a new cluster from scratch could someone please share the steps or documents and also if one subscriber fail in already built cluster then what to do
Are you setting up a new environment or are you doing a fresh install and then DRS restore? What version?
setting up a new environment. so could you please advise on from scratch how to do. i have never done it so far. is there any cisco doc or link please share ....
Use the link below for the guides and references. You didn't specify what version you were installing so I couldn't link the exact install guide. Those links should get you started assuming you have the physical server infrastructure in place, the cucm ova file and iso.
https://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-callmanager/products-installation-guides-list.html
Cisco Live doc for UCM 12.x
https://www.ciscolive.com/global/on-demand-library.html?search=cucm%20install#/session/1540336593046001DbNj
Cisco Live doc for Enterprise Dial Plan Fundamentals
https://www.ciscolive.com/global/on-demand-library.html?search=dial%20plan#/session/1509501667187001Ppml
thanks much for your support
Jaime Valencia
CUCM/IM&P installation guide covers all the steps for installation of first node and subsequent nodes.
As to what to do if a SUB fails, that depends on whether you have a DRS backup or not. If you have a DRS backup, refer to that documentation for further information.
java
if this helps, please rate
Hi Jaime,
Thanks for your reply. if we dont have DRS backup then how we will proceed. please reply.
your response is solicited.
thank you
