how to change codec to g729r8 from default g711
sarahr202
Level 5
Level 5
Hi everybody
Please consider the following set up.
                                              (201.201.201.1)
Ipphone1(201.201.201.11)--------CME------------------------ipphone2(201.201.201.12)
Our design requires ipphone1 to use codec g729r8 not default g711.
I did some research and found I could use these commands to accomplish that:
Router(config)# ephone 1
Router(config-ephone)# codec g729r8
However, I still see CME is sending open receive channel with payload capability:
G.711 u-law 64k (4). Below is the packet capture
No.     Time        Source                Destination           Protocol Length Info
    118 18.025218   201.201.201.1         201.201.201.11        SKINNY   134    OpenReceiveChannel
Frame 118: 134 bytes on wire (1072 bits), 134 bytes captured (1072 bits)
Ethernet II, Src: Cisco_37:8a:c0 (00:12:d9:37:8a:c0), Dst: Cisco_7b:84:ef (00:06:53:7b:84:ef)
Internet Protocol Version 4, Src: 201.201.201.1 (201.201.201.1), Dst: 201.201.201.11 (201.201.201.11)
Transmission Control Protocol, Src Port: cisco-sccp (2000), Dst Port: 49527 (49527), Seq: 1601, Ack: 153, Len: 80
Skinny Client Control Protocol
    Data length: 72
    Header version: Basic (0x00000000)
    Message ID: OpenReceiveChannel (0x00000105)
    Conference ID: 2
    Pass-thru party ID: 0
    MS/packet: 20
   Payload capability: G.711 u-law 64k (4)
    Echo-cancel type: Media_EchoCancellation_On (1)
    G723 bitrate: Media_G723BRate_6_4 (2)
1) How can configure CME to instruct ipphone1 to use desired codec not default?
Thanks and have agreat weekend.
Ayodeji Okanlawon
As suggested earlier the codec is changed on the ephone as you have done
Can you send a debug ephone state...Also when you do a test call, once the call is connected press the ? button twice, you should see the codec the phone is using
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Ayodeji Okanlawon
Hi there
Router#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#ephone 1
Router(config-ephone)#codec?
codec
Router(config-ephone)#codec ?
  g711ulaw  Use G.711 u Law 64000 bps voice codec (default)
  g729r8    Use G.729 8000 bps voice codec to save network bandwidth
Router(config-ephone)#codec g729r8
Next I unplug the phones and plug it back
Router#debug ephone state
EPHONE state debugging is enabled
Router#
00:31:15: ephone-2[2][SEP000628F0F7E7]:Keepalive TIMEOUT on socket [2] ephone-2
SEP000628F0F7E7
00:31:15: ephone-2[2]:DisAssociate: Closed socket 2 while REGISTERED
00:31:15: ephone-2[2][SEP000628F0F7E7]: DN out-of-service for DN 2 chan 1
00:31:15: Skinny DN 2 chan 1 state change to DOWN
00:31:15: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-2:SEP000628F0F7E7 IP:201.201.20
1.12 Socket:2 DeviceType:Phone has unregistered abnormally.
00:31:19: ephone-1[1][SEP0006537B84EF]:Keepalive TIMEOUT on socket [1] ephone-1
SEP0006537B84EF
00:31:19: ephone-1[1]:DisAssociate: Closed socket 1 while REGISTERED
00:31:19: ephone-1[1][SEP0006537B84EF]: DN out-of-service for DN 1 chan 1
00:31:19: Skinny DN 1 chan 1 state change to DOWN
Router#
00:31:19: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-1:SEP0006537B84EF IP:201.201.20
1.11 Socket:1 DeviceType:Phone has unregistered abnormally.
I plug the phones back now
Router#
00:33:27: %IPPHONE-6-REG_ALARM: 25: Name=SEP000628F0F7E7 Load=8.0(5.0) Last=Init
ialized
00:33:27: ephone-(2)[1] Register StationIdentifier DeviceName SEP000628F0F7E7
00:33:27: ephone-2[-1]:stationIpAddr 201.201.201.12
00:33:27: ephone-2[-1]:Found entry 1 for 000628F0F7E7
00:33:27: ephone-2[-1]:socket change -1 to 1
00:33:27: ephone-2[1]:phone SEP000628F0F7E7 re-associate OK on socket [1]
00:33:27: %IPPHONE-6-REGISTER: ephone-2:SEP000628F0F7E7 IP:201.201.201.12 Socket
:1 DeviceType:Phone has registered.
00:33:27: ephone-2[1][SEP000628F0F7E7]: DN in-service for DN 2 chan 1
00:33:27: Skinny DN 2 chan 1 state change to UP
00:33:32: %IPPHONE-6-REG_ALARM: 25: Name=SEP0006537B84EF Load=8.0(5.0) Last=Init
ialized
00:33:32: ephone-(1)[2] Register StationIdentifier DeviceName SEP0006537B84EF
00:33:32: ephone-1[-1]:stationIpAddr 201.201.201.11
00:33:32: ephone-1[-1]:Found entry 0 for 0006537B84EF
00:33:32: ephone-1[-1]:socket change -1 to 2
00:33:32: ephone-1[2]:phone SEP0006537B84EF re-associate OK on socket [2]
00:33:32: %IPPHONE-6-REGISTER: ephone-1:SEP0006537B84EF IP:201.201.201.11 Socket
:2 DeviceType:Phone has registered.
00:33:32: ephone-1[2][SEP0006537B84EF]: DN in-service for DN 1 chan 1
00:33:32: Skinny DN 1 chan 1 state change to UP
00:33:37: ephone-2[1]:SetCallState line 1 DN 2(-1) chan 1 ref 0 TsOnHook
Router#
Router#
00:33:42: ephone-1[2]:SetCallState line 1 DN 1(-1) chan 1 ref 0 TsOnHook
Both phones have been registered .
Next I make a call from ipphone1(20001)to ipphone2(20002)
0:36:39: ephone-1[2]:OFFHOOK
00:36:39: ephone-1[2]:---SkinnySyncPhoneDnOverlays is onhook
00:36:39: ephone-1[2]:SIEZE on activeLine 0 activeChan 1
00:36:39: ephone-1[2]:SetCallState line 1 DN 1(-1) chan 1 ref 5 TsOffHook
00:36:39: ephone-1[2]:Check Plar Number
00:36:39: DN 1 chan 1 Voice_Mode
00:36:39: dn_tone_control DN=1 chan 1 tonetype=33:DtInsideDialTone onoff=1 pid=1
72
00:36:41: dn_tone_control DN=1 chan 1 tonetype=0:DtSilence onoff=0 pid=172
00:36:41: ephone-1[2]:
bulk_sd_search_lists: button= 0 state NOT_IN_SD
00:36:42: ephone-1[2]:
00:36:43: ephone-1[2]:
bulk_sd_search_lists: button= 2 state NOT_IN_SD
00:36:43: ephone-1[2]:Skinny-to-Skinny call DN 1 chan 1 to DN 2 chan 1 instance
00:36:43: ephone-1[2]:SetCallState line 1 DN 1(-1) chan 1 ref 5 TsProceed
00:36:43: ephone-1[2]:SetCallState line 1 DN 1(-1) chan 1 ref 5 TsRingOut
00:36:43: ephone-1[2]::callingNumber 20001
00:36:43: ephone-1[2]::callingParty 20001
00:36:43: ephone-1[2]:Call Info DN 1 line 1 ref 5 call state 1 called 20002 call
ing 20001 origcalled
00:36:43: ephone-1[2]:Call Info DN 1 line 1 ref 5 called 20002 calling 20001 ori
gcalled 20002 calltype 2
00:36:43: ephone-1[2]:Call Info for chan 1
00:36:43: ephone-1[2]:SkinnyDisplayCallInfo No-callingName
00:36:43: ephone-1[2]:SkinnyDisplayCallInfo No-calledName
00:36:43: ephone-2[1]:SetCallState line 1 DN 2(2) chan 1 ref 6 TsRingIn
00:36:43: ephone-2[1]::callingNumber 20001
00:36:43: ephone-2[1]::callingParty 20001
00:36:43: ephone-2[1]:Call Info DN 2 line 1 ref 6 call state 7 called 20002 call
00:36:43: ephone-2[1]:Call Info DN 2 line 1 ref 6 called 20002 calling 20001 ori
gcalled 20002 calltype 1
00:36:43: ephone-2[1]:Call Info for chan 1
00:36:43: ephone-2[1]:SkinnyDisplayCallInfo No-callingName
00:36:43: ephone-2[1]:SkinnyDisplayCallInfo No-calledName
00:36:43: ephone-2[1]:Ringer Inside Ring On
00:36:43: dn_tone_control DN=1 chan 1 tonetype=36:DtAlertingTone onoff=1 pid=172
00:36:44: ephone-1[2]::callingNumber 20001
00:36:44: ephone-1[2]::callingParty 20001
00:36:44: ephone-1[2]:Call Info DN 1 line 1 ref 5 call state 1 called 20002 call
00:36:44: ephone-1[2]:Call Info DN 1 line 1 ref 5 called 20002 calling 20001 ori
00:36:44: ephone-1[2]:Call Info for chan 1
00:36:44: ephone-1[2]:SkinnyDisplayCallInfo No-callingName
00:36:44: ephone-1[2]:SkinnyDisplayCallInfo No-calledName
00:36:46: ephone-2[1]:OFFHOOK
00:36:46: ephone-2[1]:---SkinnySyncPhoneDnOverlays is onhook
00:36:46: ephone-2[1]:Ringer Off
00:36:46: ephone-2[1]:ANSWER call
00:36:46: ephone-2[1]:SetCallState line 1 DN 2(-1) chan 1 ref 6 TsOffHook
00:36:46: ephone-2[1][SEP000628F0F7E7]:Answer Incoming call from ephone-(1) DN 1
chan 1
00:36:46: ephone-2[1]:SetCallState line 1 DN 2(-1) chan 1 ref 6 TsConnected
00:36:46: defer_start for DN 1 chan 1 at CONNECTED
00:36:46: ephone-1[2]:SetCallState line 1 DN 1(-1) chan 1 ref 5 TsConnected
00:36:46: ephone-2[1]::callingNumber 20001
00:36:46: ephone-2[1]::callingParty 20001
00:36:46: ephone-2[1]:Call Info DN 2 line 1 ref 6 call state 4 called 20002 call
00:36:46: ephone-2[1]:Call Info DN 2 line 1 ref 6 called 20002 calling 20001 ori
00:36:46: ephone-2[1]:Call Info for chan 1
00:36:46: ephone-2[1]:SkinnyDisplayCallInfo No-callingName
00:36:46: ephone-2[1]:SkinnyDisplayCallInfo No-calledName
00:36:46: ephone-1[2]:OpenReceive DN 1 chan 1 codec 4:G711Ulaw64k  duration 20 m
s bytes 160
00:36:46: ephone-2[1]:OpenReceive DN 2 chan 1 codec 4:G711Ulaw64k  duration 20 m
s bytes 160
00:36:46: dn_tone_control DN=1 chan 1 tonetype=0:DtSilence onoff=0 pid=172
00:36:46: DN 2 chan 1 Voice_Mode
00:36:46: DN 1 chan 1 End Voice_Mode
00:36:46: DN 1 chan 1 Voice_Mode
00:36:46: ephone-1[2]:OpenReceiveChannelAck codec has changed from 4 to 11
00:36:46: ephone-1[2]:CloseReceive
00:36:46: ephone-1[2]:StopMedia
00:36:46: ephone-1[2]:OpenReceive DN 1 chan 1 codec 11:G729  duration 20 ms byte
s 20
00:36:46: ephone-2[1]:OpenReceiveChannelAck codec has changed from 4 to 11
00:36:46: ephone-2[1]:CloseReceive
00:36:46: ephone-2[1]:StopMedia
00:36:46: ephone-2[1]:OpenReceive DN 2 chan 1 codec 11:G729  duration 20 ms byte
s 20
00:36:46: ephone-1[2]:OpenReceiveChannelAck:IP 201.201.201.11, port=20030,
               dn_index=1, dn=1, chan=1
00:36:46: ephone-2[1]:StartMedia 201.201.201.11 port=20030
00:36:46: DN 1 chan 1 codec 11:G729 duration 20 ms bytes 20
00:36:46: ephone-2[1]:OpenReceiveChannelAck:IP 201.201.201.12, port=20596,
               dn_index=2, dn=2, chan=1
00:36:46: ephone-1[2]:StartMedia 201.201.201.12 port=20596
00:36:46: DN 2 chan 1 codec 11:G729 duration 20 ms bytes 20
00:36:47: ephone-1[2]::callingNumber 20001
00:36:47: ephone-1[2]::callingParty 20001
00:36:47: ephone-1[2]:Call Info DN 1 line 1 ref 5 call state 4 called 20002 call
00:36:47: ephone-1[2]:Call Info DN 1 line 1 ref 5 called 20002 calling 20001 ori
00:36:47: ephone-1[2]:Call Info for chan 1
00:36:47: ephone-1[2]:SkinnyDisplayCallInfo No-callingName
00:36:47: ephone-1[2]:SkinnyDisplayCallInfo No-calledName
00:36:48: ephone-2[1]:ONHOOK (from phone msgID=7)
00:36:48: ephone-1[2]:CloseReceive
00:36:48: ephone-1[2]:StopMedia
00:36:48: ephone-2[1]:call clean up this DN 2 chan 1 was called by other DN 1 ch
an 1
00:36:48: this ephone-2 other ephone-(1) other DN state CONNECTED
00:36:48: ephone-2[1]:CloseReceive
00:36:48: ephone-2[1]:StopMedia
00:36:48: DN 2 chan 1 End Voice_Mode
00:36:48: Reset called DN binding for DN 1 (was 2)
00:36:48: ephone-2[1]:SetCallState line 1 DN 2(-1) chan 1 ref 6 TsOnHook
00:36:48: ephone-2[1]:SpeakerPhoneOnHook
00:36:48: DN 1 chan 1 End Voice_Mode
00:36:48: ephone-1[2]:SetCallState line 1 DN 1(-1) chan 1 ref 5 TsOnHook
00:36:48: ephone-1[2]:SpeakerPhoneOnHook
00:36:48: ephone-1[2]:ONHOOK (internal)
00:36:48: ephone-2[1]:---SkinnySyncPhoneDnOverlays is onhook
00:36:49: SkinnyReportDnState DN 1 chan 1 ONHOOK
,CME has to send " Open receive channel " twice. I was a little suspicious may be  i am hallucinating.
Performed packet capture, which indeed shows open receive channel " sent twice. One with codec g711, the second one with g729.
"113","15.421039","201.201.201.1","201.201.201.11","SKINNY","134","OpenReceiveChannel "
116 15.442593 201.201.201.11 201.201.201.1 SKINNY 86 OpenReceiveChannelAck
118 15.529320 201.201.201.1 201.201.201.11 SKINNY 78 CloseReceiveChannel
119 15.530124 201.201.201.1 201.201.201.11 SKINNY 78 StopMediaTransmission
123 15.532887 201.201.201.1 201.201.201.11 SKINNY 134 OpenReceiveChannel
127 15.550535 201.201.201.11 201.201.201.1 SKINNY 86 OpenReceiveChannelAck
The fist " open receive channel" is shown below:
    113 15.421039   201.201.201.1         201.201.201.11        SKINNY   134    OpenReceiveChannel
Frame 113: 134 bytes on wire (1072 bits), 134 bytes captured (1072 bits)
    Version: 4
    Header length: 20 bytes
    Differentiated Services Field: 0x68 (DSCP 0x1a: Assured Forwarding 31; ECN: 0x00: Not-ECT (Not ECN-Capable Transport))
    Total Length: 120
    Identification: 0xea84 (60036)
    Flags: 0x00
    Fragment offset: 0
    Time to live: 255
    Protocol: TCP (6)
    Header checksum: 0xaaf2 [correct]
    Source: 201.201.201.1 (201.201.201.1)
    Destination: 201.201.201.11 (201.201.201.11)
Transmission Control Protocol, Src Port: cisco-sccp (2000), Dst Port: 49823 (49823), Seq: 1501, Ack: 153, Len: 80
    Data length: 72
    Conference ID: 2
    MS/packet: 20
Frame 123: 134 bytes on wire (1072 bits), 134 bytes captured (1072 bits)
    Data length: 72
    Conference ID: 2
    MS/packet: 20
    Payload capability: G.729 (11)
    G723 bitrate: Media_G723BRate_5_3 (1)
Then the second.
    Version: 4
    Total Length: 120
    Identification: 0xea8a (60042)
    Flags: 0x00
    Fragment offset: 0
    Time to live: 255
    Protocol: TCP (6)
    Header checksum: 0xaaec [correct]
Transmission Control Protocol, Src Port: cisco-sccp (2000), Dst Port: 49823 (49823), Seq: 1761, Ack: 257, Len: 80
    Data length: 72
    Conference ID: 2
    MS/packet: 20
Thanks and have a great day.
