How to change recorded message in CCUM 10.5 using Greeting Administrator
sprintership
Beginner
Beginner
Experts,
I use 9999 for dialing into Greeting Administrator. I set that up long time ago. In that I have included:
790 holiday greetings
791 key voice mails
793 main message
When I try 793 I hear the message: you are not listed as the owner of this call handler.
I cannot find the place where I add 793 to the Greeting Administrator to be call owner.
790 & 791 works fine when I try to login with my extension. I completely forget when I can add my extension to that 793 call handler.
sprintership
Beginner
Beginner
Call handler owners - ehhhhhh
it is under System Call Handlers >> Call Handler >> Edit >> Call Handler Owner.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
