How to change the user password in Ip phone 7940
roopesh.n
HI All ,
How a user can change the extension mobility password in Cisco ip phone 7940.
Roopesh
10 Replies 10
Jaime Valencia
You ALWAYS need to mention what you're using for call control and version. The answer might differ and in this case it does depending on that.
I'll go with CUCM, to change the PIN use CCMuser. If 8.X or above and if provisioned, you can do it via the phone.
CCMUser will work for any version.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi ,
Very thanks for the reply.
We are using CCM 4.0. So you mean to say thereis  no other option to change the password for extension mobility except Using CCM User.
Thaks
Roopesh
It's either via CCMAdmin or CCMuser, but those are your only choices on your version.
java
java
I think we can change the password using CCM admin.
But I am asking a way for change their passwords from user's phone.
Thaks
Roopesh
We only provide that on 8.X and above as previously mentioned.
java
java
Hi ,
Thanks it helps.
Roopesh
Hi Jaime,
We are running CUCM 8.6.2 version and configured it for the "Change Credential IP Phone Service" according to
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsem.html#wp1430288
but we are getting "XML parse error" on all the Cisco 7940 phones, for other models it is working fine we are able to change the PIN. Can you please help to resolve.. does this model support this feature... as per the http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_0_1/delta/phones.html#wp1483628
we are not seeing 7940 Model in the list for this fetaure...
Rgds,
Aditya
There's a bug related to that and the phone model is already EOS/EOL, and it also doesn't show in the list of supported models
CSCts85140
ALL-LANG: 7960: XML Error occurs  on PIN change.
Since it was filed when it was already EOS/EOL, there won't be any fix for it.
If you're already on the latest FW for the phone and it happens, there's no fix.
java
java
Hi Java,
Thanks a lot for the quick response....
We have tried with Latest Firmware as well on Cisco 7940 IP phone, but the same error occur. Is their any support cisco document for the same as the feature is not supported on this Models.
Have a great Day...
Aditya
You already have the document, if it's not in the list, it's not supported.
I already mentioned that.
java
java
