How to check CUBE version in router?
adil.nasser3
What is the command to show the version of CUBE software running an IOS voice router?
Adil
Leo, your link seems to take us into infinite loop :-(
Adil, issue "sh version" which will give you the IOS version on the router, which is what most people go by, if you need to cross-reference that to CUBE version then I belive it is the same as CME version, which this matrix will provide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
HTH,
Chris
Leo Laohoo
HTH,
Chris
Sorry.  Wanted to let everyone know the different links.  If I don't put the link to the other one ...
Thank you Chris.
